JimTheGreek's avatar
Jun 14, 2021
Setup DHCP range
I'm about to do a full factory reset on my RAX80 and I'd like to reserve a range for assigned IP. What is best, to start the DHCP past the reserved range or have it at the beginning?
For clarification...
Say, start the DCHP at 100-254 and use the IPs below 100 to assign to various devices I wish to have static IP for.
Thank you in advance for any suggestions, along w/any OTHER recommendations in this process. I don't want to EVER do this again and I want more stability. (I know, wishful thinking, LOL)
Demetris
  • I have mine setup with the DHCP scope set below 100 and the reserved scope starts at 101.  It works for me but that is just my preference.
    • > [...] What is best, to start the DHCP past the reserved range or have
         Define "best".  What difference would it make?
         So long as the ".100" - ".254" range is big enough for your DHCP-pool
      needs, and the ".2" - ".99" range is big enough for your non-pool
      needs, that should work.  (What could go wrong?)
      > scope starts at 101. [...]
         Putting the dividing line among the ".1xx" values is not the way I'd
      do it.  As proposed above, _all_ ".1xx" and ".2xx" values are in the
      same category.  No need for thought.  And, in the words of the
      philosopher Williams, "If you don't think too good, don't think too
      much."
      • Well folks!
        The reason I ask, is because last week or so, I read a post saying that having the assigned IP area at the start (.1-.99) then then the DHCP pool. They talked about how the router starts looking to assign IPS, I don’t recall details & I wish I would’ve kept it.
        Thank you all for your input! Tomorrow I’ll do it & see what color smoke I get. (Only OLD engineers like me would understand that. )
