gbridgeman
Dec 30, 2019Follower
setup of nighthawk ac1900 behind Att uverse router
My router provided by ATT has too many devices attached so I bought the Nighthawk since users said is can go behind the primary ATT router. I cannot connect to the new router. There are no direc...
Dec 30, 2019Guru - Experienced User
A couple things.
1. you put nighthawk router but your signature lists the C7100v which is cable modem/router.
2. You put that you have att with a att router. running 2 routers on a network puts you in a double nat. You can get around this by placing the att in pass through/modem only or a regular router in AP (access point mode). But that option isn't availble if you have the C7100V.
https://kb.netgear.com/30186/What-is-Double-NAT
So what actual router did you buy?
You can go to netgear.com/support/ type in your actual model number and it has install videos, install instructions, manuals, and firmware.
