DudeRides
Mar 20, 2020Aspirant
Should I Try To Block These IP's?
Hello, With two people now working from home, I have noticed some unusual behaviors/slowdowns in browser response. I'm just learning the basics as far as diagnosing what might be improved and loo...
michaelkenward
Mar 21, 2020Guru - Experienced User
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
DudeRides wrote:
Is the first/basic step to block the source IP's?
Not if you want to use those sites.
DudeRides
Mar 21, 2020Aspirant
Interesting. I parsed through most of the log from Thursday/Friday and indeed most of the IP addresses were from Charter, but there were a few from China and Indonesia.
Rather than blocking IP addresses, should I look for Ports to block?
- michaelkenwardMar 21, 2020Guru - Experienced User
- DudeRidesMar 21, 2020Aspirant
What tool is used to block IP's or Ports? I can't seem to find anything onboard the router to do so...
Check the manual for your device. AX12 could be one of several things.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find the documentation.
Look for the model number on the label on the device.
- SAM_the_GAMMar 22, 2020Luminary
DudeRides wrote:Interesting. I parsed through most of the log from Thursday/Friday and indeed most of the IP addresses were from Charter, but there were a few from China and Indonesia.
My internet provider is Spectrum (Charter) and had many DOS logged coming from IP within Spectrum. I was using an older firmware version for my router RAX80 1.0.1.56 after I upgraded to the latest 1.0.1.70 the entries went away. I believe the log entries with the older firmware were logged falsely. Because the router was logging the DOS attacks so often it was slowing down my connection. After I upgraded the firmware internet speed has returned to normal & no more DOS attack in the log.
- michaelkenwardMar 22, 2020Guru - Experienced User
Yup. That's what I said earlier, but it didn't seem to satisfy DudeRides.
Thanks for providing concrete evidence with related hardware.
- DudeRidesMar 22, 2020Aspirant
My firmware is already on the latest (1.0.1.114) so I can't at the moment eliminate the DoS entries from the log, however, I accept that they may be false. Nevertheless I'm left trying to dianose why the addition of my wife's work PC to the network has resulted in a change in the behavior of the network. A response on a different forum has suggested that I place her work PC on an isolated "VLAN". Thoughts?
