prr's avatar
prr
Should I use WPA/WPA2 on home router?
Just got a Nighthawk RAX35. It replaced an older Linksys and my internet speed is now double what it was yesterday. :)
I do have one question. Poking around the security settings & pages here, I saw that netgear recommends WPA/WPA2 security. I logged in to routerlogin.net on my phone, and I was able to get to the page that allowed me to choose the settings. But after hitting Apply, it tells me that the IP is invalid. I went back and entered the IP for the router, and I got the same error message.
What am I supposed to do? Or should I even worry about that level of router security for a home network?
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello prr,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
  • I think you need to use the Netgear app or update via a computer.  Don't use WPA, its a weak form of security.
    Set to WPA3 Personal for better security, if you have only WIFI6 devices.  Set to WPA2/WPA3 Transitional for compatibility with older devices
