Canuck521
Sep 10, 2024Aspirant
Simple IP based port triggering
Hello,
I have 3 incoming port setup for port forwarding.
They are used to send print jobs form a supporting company to some local printers.
the same port(s) being used on both ends, so that was very simple to setup (printers also have fixed IPs).
I am wondering how to lock down the port forwarding to only allow forwards from Specific IPs.
If I were doing a Unix (IPFW) rule, what I might currently have is
allow all TCP from ALL 9104 to 192.167.0.10 9104
What I really want is something like:
allow ALL from 10.11.12.13 9104 TO 192.168.1.10 9104
Is this possible?
we are using a Nighthawk RAX70.
1 Reply
- Canuck521Aspirant
Hello,
I have 3 incoming port forwarding rules to allow remote IPs (WAN) to connect to 3 specific printers on the internal network. Of course, the port forwarding rules open those ports for all incoming (WAN) connections.
I am wanting to create some ACL rules to limit access to those ports form the specific remote IPs only.
Is this possible through the Nighthawk ACL facility?
