DesignAlot
Dec 18, 2024Aspirant
[site blocked: 1d.tlu.dl.delivery.mp.microsoft.com]
I am getting MANY emails EVERY day, in regards to the Netgear log blocking the below site. How do I add this site to the safe list to stop getting tons of email alerts?! I have an AX9 RAX70 Nighthawk...
- Dec 19, 2024
Ok, I figured this out! I had site blocking on in my router settings based on certain keywords. I totally disabled the site blocking function, I stopped getting the site blocked notifications. This site that was blocked completely has to do with the Microsoft store app in my Windows 11. In my router, I looked up the two assigned ip addresses with the issues. They were my desktop PC and my Microsoft Surface Pro. I opened the Microsoft store app on both, and saw that an update was stuck on each device (both different product updates, this can happen with any one of them). When I quit the download/update attempt and then restarted the update attempts, I got the error log notice via email from my router! So after temporarily turning off the site block, I could finish the Microsoft store downloads/updates. I then enabled my site blocking again and no more notices for now. I will know what to do next time this happens. I have a daughter, so I have certain keywords that may be on websites blocked and I will continue to use this feature. At least I can identify which device, and check the Microsoft store app for "stuck" downloads. Hope this helps some people.
DesignAlot
Dec 19, 2024Aspirant
Dec 19, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
