thehypnootoad
Nov 17, 2021Luminary
Sky rax120
Rax120 option 61 dchp why can't this be implemented I keep asking and get nothing back it's costing me 30 pound more a month as I can't have a sky broadband which in turn not been able to get a better...
Nov 17, 2021Guru - Experienced User
Not sure if its related because the RAX120 is a qualcom based router versus the ones that support it are either broadcom or intel based.
Which NETGEAR routers support DHCP option 60 and 61? | Answer | NETGEAR Support
got an old router that does support those options? you could always use that router and disable its wifi and connect the RAX in access point mode.
thehypnootoad
Thanks I do have a d7000 with antitrust but wanted the rax in router mode as use a vpn and certain other features would make it pointless.
- plemansNov 17, 2021Guru - Experienced User
does it work if you put the RAX's IP address into the D7000's dmz?
- thehypnootoadNov 19, 2021LuminaryIt's the features on the rax120 I need to use like the vpn which works perfect I don't think the d7000 supports it. It's ridiculous though as my bill for sky and bt is 92 quid a month as it could be 62 if Netgear just supported it .where is a Netgear rep to explain why they can't do it.
- plemansNov 19, 2021Guru - Experienced User
This is the community support forum. Where members of the public help out.
Its not netgear. There's the rare mod on here but its not frequent.
