thehypnootoad
Nov 17, 2021Luminary
Sky rax120
Rax120 option 61 dchp why can't this be implemented I keep asking and get nothing back it's costing me 30 pound more a month as I can't have a sky broadband which in turn not been able to get a better...
thehypnootoad
Thanks I do have a d7000 with antitrust but wanted the rax in router mode as use a vpn and certain other features would make it pointless.
Nov 17, 2021Guru - Experienced User
does it work if you put the RAX's IP address into the D7000's dmz?
- thehypnootoadNov 19, 2021LuminaryIt's the features on the rax120 I need to use like the vpn which works perfect I don't think the d7000 supports it. It's ridiculous though as my bill for sky and bt is 92 quid a month as it could be 62 if Netgear just supported it .where is a Netgear rep to explain why they can't do it.
- plemansNov 19, 2021Guru - Experienced User
This is the community support forum. Where members of the public help out.
Its not netgear. There's the rare mod on here but its not frequent.
- thehypnootoadNov 20, 2021Luminary
I know you are as it normally says netgear on there logo. Netgear are a joke though.
