thehypnootoad
Nov 17, 2021Luminary
Sky rax120
Rax120 option 61 dchp why can't this be implemented I keep asking and get nothing back it's costing me 30 pound more a month as I can't have a sky broadband which in turn not been able to get a better...
Nov 17, 2021Guru - Experienced User
Not sure if its related because the RAX120 is a qualcom based router versus the ones that support it are either broadcom or intel based.
Which NETGEAR routers support DHCP option 60 and 61? | Answer | NETGEAR Support
got an old router that does support those options? you could always use that router and disable its wifi and connect the RAX in access point mode.
penguinpages
Nov 17, 2021Tutor
I had similar issues with my rax120. For $500+ I expected a better UI to set those kinds of things, or at least SSH to set via CLI. Nope. I had to abandon it for DHCP.
