BigshotMD
Oct 21, 2022Aspirant
Slow 2.4 GHz wifi on RAX120v1
I am wondering if any one else is experiencing very slow internet download speeds on their RAX120v1 router on 2.4 GHz wifi network. Current firmware version = 1.2.8.40 Smart Connect = Off Same ...
Oct 21, 2022Guru - Experienced User
What actual speeds do you get?
2.4ghz is much slower than 5ghz and its more sensitive to interference.
So we expect it to be slower and have more issues.
But its tough to know if you're hitting the expected speeds and just don't realize it or if its just slow.
Also, what device are you testing on?
- BigshotMDOct 22, 2022Aspirant
Hi Plemans,
Thanks so much for your input. I've written a reply above to provide you with more information.
I look forward to your input.
