BigshotMD
Oct 21, 2022Aspirant
Slow 2.4 GHz wifi on RAX120v1
I am wondering if any one else is experiencing very slow internet download speeds on their RAX120v1 router on 2.4 GHz wifi network. Current firmware version = 1.2.8.40 Smart Connect = Off Same ...
Oct 26, 2022Guru - Experienced User
What internet speeds do you pay for?
Thats how I usually test unless I'm testing speeds faster than my ISP supplies.
And if you're hitting 229mbps over 2.4ghz and only 63mbps over 5ghz, somethings wrong there. The 5ghz should be significantly faster than 2.4ghz.
BigshotMD
Oct 27, 2022Aspirant
Perhaps I may not be clear with the speeds
Wifi speed is very different than internet speed.
229mbps is the 2.4GHz Wifi link speed, but internet on this band is intermittently very slow as if the router is blocking traffic on this band
This does not happen with 5GHz band.
- plemansOct 27, 2022Guru - Experienced User
What actual speeds do you get then? you still haven't said. Just the link speed.
And you will run into intermittent issues on 2.4ghz. Again, its a slower network and more sensitive to interference because of the smaller amount of channels available and channel overlap. Thats why there's a 5ghz network. Because of that issue with 2.4ghz.
- BigshotMDOct 28, 2022AspirantI’ve tried to do an internet speed test during the intermittently slow internet speeds. Unable to test as it is so slow that speed test page doesn’t run properly.
Maybe it could be interference but would have thought changing to manual channel with channel sniffer would improve this. Instead it has worsened it.
If there is no solution or we are sure that it is not firmware related then I will have to accept it as possible interference.- BigshotMDDec 02, 2022Aspirant
Thanks for your post.
Since my original post, I have upgraded my iPhone to the current iPhone 14 Pro. Strangely, there has been some improvement and I haven't noticed the problem as much. Perhaps it may be hardware with possible interference at the 2.4 GHz band.
