Ignitionnet
Mar 14, 2023Tutor
Slow download, normal upload, sending TX pauses though flow control off
So the switch in the RAXE500 I have here seems to be malfunctioning. The router is being used as an access point,the issues persist whether used in AP mode or as a router. It is unable to achieve...
- Mar 19, 2023
Some more work has proved beyond doubt that there's a pretty big issue with how the device handles links of different speeds. This is really not good for a device with a single 2.5G port, 4 1G ports and WiFi that's easily capable of over a gigabit.
So I pulled it out of the network and replaced with an older Netgear that has the exact same issues but that's another story.
Connecting it via a cable to the network via the 2.5G port, and a gigabit port to the computer causes slow download due to pause frames sent by the router on the 2.5G port to the actual router handling the Internet connection.
Connecting via a cable to the network via the 1G port and 2.5G port to the computer causes slow upload due to pause frames sent by the router on the 2.5G port to the computer.
Connecting to the computer and the network via 1G ports all is fine.Connecting to the network via the 2.5G port and using 6E WiFi causes slow download, correct upload - the WiFi is slower than the 2.5G port so pause frames are being sent down the 2.5G port by the Netgear.
Router mode, having the Netgear NAT which I don't want it to do, all is normal. The device doesn't work properly as an access point and can't handle different speed ports via its switch making LAN to LAN transfers problematic and access point mode pointless.
I'm taking this up with their Gearhead support tomorrow which should be exciting.
Ignitionnet
Mar 17, 2023Tutor
plemans wrote:Your RAXE should be connected via its wan port in AP mode.
I've done it numerous times for testing the RAXE in AP mode. Try that
Thanks. I have. Doesn't make any difference which port I'm using.
Ignitionnet
Mar 17, 2023Tutor
The RX pauses tell my kit to stop transmitting for a millisecond at a time which kills download throughput. The Netgear can't handle the imbalance between speeds in each direction and responds with flow control pause frames even though it's explicitly configured not to.
It stops doing this the issue goes away. Most folks probably aren't using kit that honors these.
The chain is 8G Internet <> CCR2116 <> 10G via two switches <> Gigabit / 2.5 Gigabit on RAXE.
I expect the flow to bottleneck, however I expect that to be managed, per configuration, by the protocols running over the Ethernet into the AP, not the AP itself.
- FURRYe38Mar 17, 2023Guru - Experienced User
What is the brand and model of the switches in the mix?
What CAT# lan cable are you using? CAT6A STP is recommended.
- IgnitionnetMar 17, 2023Tutor
FURRYe38 wrote:What is the brand and model of the switches in the mix?
Hi,
No errors on any of the links. The cables are a very short stretch of CAT 7, a 10G DAC, 30 ft of single mode fibre, another DAC. The only cable run over 3 ft is fibre and it's running cleanly.
The switches are combination Mikrotik and QNAP. They are all working as expected. The issue is the Netgear ignoring the configuration and choking the link with heavy use of flow control.
Transfers not going through the Netgear but using the exact same switches and end router as it, plugged in the same switch as it, run fine. It is the common point of failure throughout.- FURRYe38Mar 17, 2023Guru - Experienced User
Is the cable UTP or STP rated? STP would be recommended.
I guess keep in touch with NG support. Ask them about getting them debug logs from your unit while in AP mode. Possible faulty unit as well. Others haven't reported this.
