Marat2k6
Oct 08, 2019Tutor
Slow download speeds on ethernet
I received my RAX200 3 days ago. When setting it up i updated the firmware to the latest version and didnt make much changes at all besides renaming the wifi bands. I have a 1gb connection, and the r...
Oct 08, 2019Guru - Experienced User
I've got the same issue with my RAX200. A couple things you can try.
manually set your qos speed for 1 gig download and ****upload (whatever your upload speed is).
disable qos. Or enable it.
Enable ivp6.
Reset the device after a firmware update. I've had better success installing, resetting, and then playing with my settings. I've had to go back a firmware generation to get it working full speed.
Marat2k6
Oct 08, 2019Tutor
I tried everything your suggested 3 times with each of the 3 firmwares available for this rax200. No speed difference
