Marat2k6
Oct 08, 2019Tutor
Slow download speeds on ethernet
I received my RAX200 3 days ago. When setting it up i updated the firmware to the latest version and didnt make much changes at all besides renaming the wifi bands. I have a 1gb connection, and the r...
Marat2k6
Oct 08, 2019Tutor
I tried everything your suggested 3 times with each of the 3 firmwares available for this rax200. No speed difference
Oct 08, 2019Guru - Experienced User
What I highly recommend you do is open a support case with netgear. You're not the only one having this issue and the more people that register support cases, the more resources are devoted to finding an answer. You gett 90 days of free support. To use it:
to to mynetgear at the top. Register an account and then register your device. From there you can open a support case. Again, I'd highly recommend it.
