Marat2k6
Oct 08, 2019Tutor
Slow download speeds on ethernet
I received my RAX200 3 days ago. When setting it up i updated the firmware to the latest version and didnt make much changes at all besides renaming the wifi bands. I have a 1gb connection, and the r...
Marat2k6
Nov 06, 2019Tutor
Any work around for this yet?
ChAKiBrOs
Nov 06, 2019Guide
Factory reset, enable and disable QOS, reboot so many times but nothing can help, hope netgear engineers can fix it by firmware update.
- Marat2k6Nov 20, 2019TutorSo new firmware update recently came out. 1.10
Change log says improved stability. Here's how it improved my stability so far...
- Right after update, my internet speeds top at 300mbps on my 1gb connection
- factory reset the router and set up my settings again now getting around 500-600mbps. Still not what it used to be.
- couple of my devices like my Samsung TV multiple times a day say network cable had been unplugged for a few min and then it reconnects
So far looks like this update was a step in the wrong direction - Marat2k6Dec 01, 2019TutorThe problems continue...
Yesterday the 3rd wifi signal turned off. In the settings it's on. I tried toggling it off and on...nothing. this $600 triband router now became dual band. Today devices connected to the 2nd wifi signal disconnect and reconnect happened already 5 times in last 2 hrs. My tv and my desktop that are directly connected to the router through Ethernet, get disconnected and reconnected. Says cable unplugged and 2min later it's connected again.
Now I'm gonna have to call support and see if this $600 garbage of a product can be replaced with something that actually works. - avtellaDec 01, 2019ProdigyJust ask for a RAX120, it uses a superior Qualcomm chipset. Qualcomm usually implements new features in a more stable and functional manner.
The RAX200 is essentially just an RAX80 with an extra 5Ghz band + 2.5Gb Eth port, same Broadcom WiFi chipset.
I highly doubt even even with numerous devices a triband would really make much of a difference, from my own experience. - Marat2k6Dec 04, 2019TutorSo after spending hours troubleshooting this router and finally calling support. I told them I work in IT and I've done all the troubleshooting I know plus everything I've heard they requested in their community forms. They wanted me to do all steps again while I'm on the phone before they can replace it for me. Asked for manager... Nothing.
So here's what I did I hung up on their idiotic support, I called amazon received my return label, got my money back. Ordered an Asus RT-AX88U. Record it and after a 10 min install... I have no bandwidth issues, no disconnect issues, ax band works great. And I got it on Black Friday for $250 instead of $600 and a load of headaches - mikeshinnDec 16, 2019Aspirant
OMG the phone support is maddeningly bad. I've got the same issue. Speeds are half of what they should be as everyone else has reported.
Aside form the fact that I worked for Cisco as a developer (so I've already done everything imaginable myself) they had me basically do things that wouldnt really matter, specifically: 1) manually upload the firmware (the same version the router already had installed), 2) change a the wireless channels (even though I'm running the tests from a workstation plugged directly into the router, and I told them that multiple times), and then 3) change the MTU to 1492 (theres ZERO chance thats the problem, and it wasnt). So really, the phone support was meaningless, it was all changes that wouldnt have made any difference. And then told me the troubleshooting couldnt fix it, and to to watch it for the next 12 hours - to see if its still not working correctly. Now thats a first, "yes your product is not working corrrectly now wait 12 hours and let us know if its still broken."
But then the support person tried to sell me kind of extended warranty, for a "one time fee" which made no sense at all to me because I just bought this router and he told me its still under warranty. And he kept trying to get me to buy it. Hey I'm a resonable guy, Im the CEO for a start up for goodness sake I'm pretty forgiving about technical issues these things happen, but clearly theres something wrong with these routers and the L1 people have no idea how to handle it, and they dont seem to know what to do.
Guess I'll be calling them back tomorrow to report the exact same thing I did today.
With that said, I did try some experiments and for what its worth I turned off "Portscan and DOS protection" under advanced and that consistently helped with upload speed at least (its went from 385Mbps to 935Mbps). So for anyone struggling with this, try that and it might help with upload. It did nothing to help with download. So definitely one data point, would love to know if anyone elses router performs differently when that is disabled. I'll see if I can find something equivalent for the Download side of things.
And if anyone is wondering where that is, its under Advanced -> Setup -> WAN Setup. And you should see a "Disable Port Scan and DOS Protection" option. In my case, disabling fixed the upload speed problem, but did not fix the download problem. So my guess is theres something doing some kind of equivalent inspection thats slowing downloads down. (QOS is also disabled on my rouer, enabling it had no positive effect on download speeds either).
- Marat2k6Dec 16, 2019TutorSo many people reporting same issue and people going through same troubleshooting steps with Netgear phone support and nothing helps. Of course they don't want to admit they released a bad product that was not tested properly.
Best solution is to get another wifi6 router not from Netgear - rob19aDec 30, 2019Aspirant
Im having the same issue. Router wont go above 400 Mb. I have a 1 gig connection so I should be seeing at least 900mb a sec.
This Rx router is trash. Come on netgear do better!!!
- mikeshinnJan 02, 2020AspirantI had to switch back to the version fios router in addition to the problems with the download speeds being halved, the wireless was also having problems and devices were randomly disconnecting. I’m hopefully Netgear can fix the problems with the router because the router is unworkable right now.
- Marat2k6Jan 02, 2020TutorYea this is unacceptable for such an expensive device. The Asus ax router I got after I returned the netgear has no issues
- xjnJan 02, 2020Apprentice
Marat2k6 wrote:
Yea this is unacceptable for such an expensive device. The Asus ax router I got after I returned the netgear has no issuesThe last Netgear router I had years ago had a lot of issues... I ended up switching to an AirPort and that solved all my issues. I decided to give Netgear a chance again since Apple stopped making routers... and here I am lol. I don't mind some bugs but seems a bit ridiculous for basic features to not work or have to disable everything purchased it for just to get it to work as well as a cheaper model.
mikeshinn wrote:
I had to switch back to the version fios router in addition to the problems with the download speeds being halved, the wireless was also having problems and devices were randomly disconnecting. I’m hopefully Netgear can fix the problems with the router because the router is unworkable right now.The router has been out for a year now... I've given up hope on a fix after reading about same issues all year. All I can do is check here daily for some updates... was hoping to see someone say they finally found a fix but so far only consistent fix I've seen all year is to return the router.
