Wmta
Jan 10, 2021Aspirant
Slow nighthawk
Replaced my coal fired AirportExtreme with an RAX120 in order to take full advantage of our shiny new gigabit internet feed. The AE generated thruput,as indicated by the Speedtest app, close to 90...
michaelkenward
Jan 11, 2021Guru - Experienced User
What feeds the RAX120? The modem equivalent?
Wmta wrote:
- After installing my shiny new (rebuilt) RAX120 I am getting less than 180 on wire to my desktop (imac) and less than 80 on wireless.
What does "rebuilt" mean? You bought it second hand?
Did you factory reset it before you out it to use?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and use the community search to find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
Wmta
Jan 11, 2021Aspirant
The router is a refurbished unit purchased through Amazon.
The router is fed by a new gigabit modem made by Arris.
It was reset and the firmware updated when I installed it.
I posted here because it IS a router.
- michaelkenwardJan 11, 2021Guru - Experienced User
Wmta wrote:
I posted here because it IS a router.Yes, but not one supported in this section.
Should you have enough time to search for "RAX120" or want to see what people who actually use these things say, try here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR CommunitiesIf you aren't interested in specific information from people who own and use the RAX120, by all means stick around here.
