Wmta
Jan 10, 2021Aspirant
Slow nighthawk
Replaced my coal fired AirportExtreme with an RAX120 in order to take full advantage of our shiny new gigabit internet feed. The AE generated thruput,as indicated by the Speedtest app, close to 90...
Wmta
Jan 11, 2021Aspirant
The router is a refurbished unit purchased through Amazon.
The router is fed by a new gigabit modem made by Arris.
It was reset and the firmware updated when I installed it.
I posted here because it IS a router.
michaelkenward
Jan 11, 2021Guru - Experienced User
Yes, but not one supported in this section.
Should you have enough time to search for "RAX120" or want to see what people who actually use these things say, try here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
If you aren't interested in specific information from people who own and use the RAX120, by all means stick around here.
