adubz
Dec 25, 2023Aspirant
Slow ping speeds after firmware upgrade
I was using firmware V1.0.11.94_2.0.44 when I would ping from laptop to. router using wifi I would get ping speeds around 1-2ms which is in line with what is expected on wifi. When ping the RAXE500 r...
adubz
Jan 01, 2024Aspirant
I am seeing the increased ping times on the newer FW using both wired PC directly to RAXE500 and also when my laptop is connected to the RAXE500 Wi-Fi in 5ghz mode. I am not connecting to the Fios router to run these ping tests at all. And like is said all works fine on the old FW the last 2 versions both have this problem. I don’t see any other problems other than the increased ping times on the newer FWs.
Jan 01, 2024Guru - Experienced User
Something to submit a support ticket to NG and let them know then.
