mnasiff
Dec 14, 2022Aspirant
Slow Speed Nighthawk
I have an optical connection of 900 mb but by wifi I only get 340 mb connected to the 5G signal with only 1 device connected my router is the Nighthawk RAXE290 tri-band Anyone know what might be ha...
Dec 15, 2022Guru - Experienced User
What device are you testing on?
What firmware is on the router?
HOw are you testing? What site/app/ etc?
- mnasiffDec 15, 2022Aspirant
Thanks for your answer.
I have tried (one at a time) with an iphone 13, a macbook pro, a macbook air all new from the latest generation.
The firmware is: V1.0.7.62_1
I have tested with fast.com and speedtest.netThe router indicates that it receives 600 MB upload and 900 download from the modem, this is correct, it is what I have contracted, if I connect by cable, I do receive 900/600, but as I said in my post none of my devices connected by wifi reaches more than 340 mb. I also tried with an eero router and exactly the same thing happens.
- plemansDec 15, 2022Guru - Experienced User
so if both the router from netgear and Eero are hitting the same speed, it makes me thing its the devices that are the bottleneck.
It was the first thing we thought about with the technician who helps me, I took the same devices to my brother's house who has the same internet plan that I have and with an eero router the equipment reached between 600 and 700 mb.
The technician said that he had no explanation. He had never seen a problem like this.
- michaelkenwardDec 15, 2022Guru - Experienced User
mnasiff wrote:
... as I said in my post none of my devices connected by wifi reaches more than 340 mb. I also tried with an eero router and exactly the same thing happens.
Maybe that's as fast as these devices can do, despite marketing hype.
Can you get much higher speeds if you try them on different wifi sources?
If so that would bring it back to the router. But you have tried two routers which sort of suggests that's not the problem.
Yes i can get higher speeds with the same devices.
