Chorgey
May 18, 2020Aspirant
Slow speed with RAX 80 on Wifi
I have a 300Mbps speed package with Comcast. When I plug the desktop directly into the CM1150V, I get download speeds of 325.9 Mbps, Upload is 8.7 and 16ms for ping. When I connect the desktop to...
- May 20, 2020
I just wanted to update on the situation. I needed a BIOS update and after downloading/installing, I am getting the speeds that I should be getting.
May 19, 2020Guru - Experienced User
a couple things you can try.
1. factory reset and manually reinstall the router. The rax devices are pretty new and after firmware upgrades, respond very favorably to resetting and reinstalling.
2. Make sure if you reset/reinstall, leave access control, parental controls, traffic monitoring, qos disabled. They're not recommended >250mbps.
3. Check your cables. it wouldn't be the first time a cable caused an issue
4. Try a different pc. Like the cables it wouldn't be the first time a pc/laptop was having issues with its wired port
5. try enabling ipv6.
- ChorgeyMay 20, 2020Aspirant
Thank you for the information, I'm going to work on it this weekend.
- idlacrosseplayeMay 20, 2020Tutor
Mine is slow too...
You needed a BIOS update? Do you mean firmware for the router, an iOS update, or something elsewhere? What firmware are you running? I am on V1.0.2.76_1.0.35
Can you also let me know:
- what channel you selected?
- Do you have AX on or off?
- Do you use QoS?
- did you enable IPv6?
- are you in 5GHz 4800Mbps, 2400Mbps, or 1200Mbps mode?
Thanks!
Rob
Yes
I have a Dell Desktop, after going to their website, I ran a system check and it shown that my BIOS was out of date, I downloaded and installed it.
I am also on Firmware Version V1.0.2.76_1.0.35
- what channel you selected? On 2.4Ghz, I am on Channel 11 and on 5G I am on Channel 161
- Do you have AX on or off? ON
- Do you use QoS? OFF
- did you enable IPv6? NO
- are you in 5GHz 4800Mbps, 2400Mbps, or 1200Mbps mode? 2400Mbps
also, in Advanced>Wireless Settings for both 2.4 and 5G, I have...
Fragmentation Length 2300
CTS/RTS Threshold 2301
and in ADVANCED > Setup > WAN Setup...
In the MTU Size field, I entered a value of 1472
as suggested by support.
Don't forget to Power Cycle..
>> remove the router from the main power supply.
>>remove the modem from the main power supply.
>>wait for 2 min
>> power ON your modem.
>>once the modem is stable then power ON your router.Hope it helps... this was driving me up a wall for a little over a week.
