Chorgey
May 18, 2020Aspirant
Slow speed with RAX 80 on Wifi
I have a 300Mbps speed package with Comcast. When I plug the desktop directly into the CM1150V, I get download speeds of 325.9 Mbps, Upload is 8.7 and 16ms for ping. When I connect the desktop to...
- May 20, 2020
I just wanted to update on the situation. I needed a BIOS update and after downloading/installing, I am getting the speeds that I should be getting.
May 19, 2020Guru - Experienced User
a couple things you can try.
1. factory reset and manually reinstall the router. The rax devices are pretty new and after firmware upgrades, respond very favorably to resetting and reinstalling.
2. Make sure if you reset/reinstall, leave access control, parental controls, traffic monitoring, qos disabled. They're not recommended >250mbps.
3. Check your cables. it wouldn't be the first time a cable caused an issue
4. Try a different pc. Like the cables it wouldn't be the first time a pc/laptop was having issues with its wired port
5. try enabling ipv6.
Chorgey
May 20, 2020Aspirant
Thank you for the information, I'm going to work on it this weekend.
