Chorgey's avatar
Chorgey
Slow speed with RAX 80 on Wifi
I have a 300Mbps speed package with Comcast. When I plug the desktop directly into the CM1150V, I get download speeds of 325.9 Mbps, Upload is 8.7 and 16ms for ping.   When I connect the desktop to...
  • Chorgey's avatar
    Chorgey
    May 20, 2020
    I just wanted to update on the situation. I needed a BIOS update and after downloading/installing, I am getting the speeds that I should be getting.
