Chorgey
May 18, 2020Aspirant
Slow speed with RAX 80 on Wifi
I have a 300Mbps speed package with Comcast. When I plug the desktop directly into the CM1150V, I get download speeds of 325.9 Mbps, Upload is 8.7 and 16ms for ping. When I connect the desktop to...
- May 20, 2020
I just wanted to update on the situation. I needed a BIOS update and after downloading/installing, I am getting the speeds that I should be getting.
Chorgey
May 20, 2020Aspirant
idlacrosseplaye
May 20, 2020Tutor
Mine is slow too...
You needed a BIOS update? Do you mean firmware for the router, an iOS update, or something elsewhere? What firmware are you running? I am on V1.0.2.76_1.0.35
Can you also let me know:
- what channel you selected?
- Do you have AX on or off?
- Do you use QoS?
- did you enable IPv6?
- are you in 5GHz 4800Mbps, 2400Mbps, or 1200Mbps mode?
Thanks!
Rob
- ChorgeyMay 20, 2020Aspirant
Yes
I have a Dell Desktop, after going to their website, I ran a system check and it shown that my BIOS was out of date, I downloaded and installed it.
I am also on Firmware Version V1.0.2.76_1.0.35
- what channel you selected? On 2.4Ghz, I am on Channel 11 and on 5G I am on Channel 161
- Do you have AX on or off? ON
- Do you use QoS? OFF
- did you enable IPv6? NO
- are you in 5GHz 4800Mbps, 2400Mbps, or 1200Mbps mode? 2400Mbps
also, in Advanced>Wireless Settings for both 2.4 and 5G, I have...
Fragmentation Length 2300
CTS/RTS Threshold 2301
and in ADVANCED > Setup > WAN Setup...
In the MTU Size field, I entered a value of 1472
as suggested by support.
Don't forget to Power Cycle..
>> remove the router from the main power supply.
>>remove the modem from the main power supply.
>>wait for 2 min
>> power ON your modem.
>>once the modem is stable then power ON your router.Hope it helps... this was driving me up a wall for a little over a week.
- idlacrosseplayeMay 20, 2020Tutor
Those settings put me to 233Mbps... :(
