EvinDtv
Aug 10, 2019Aspirant
Slow speeds over wifi
Set up my router with my gigabit connection. Using the nighthawk app I get 820 Mbps down and 600 Mbps up. When connecting via eithernet I only see 600/200 Mbps and using wifi I get 30/5 Mbps. I have ...
Aug 10, 2019Guru - Experienced User
Firmware on the RAX120?
What device are you testing with? have you tested other devices? What do they get?
Are you connecting with smart connect?
If so, disable it for speed testing. 2.4ghz has lower throughput. it should be a bit faster than that but its device specific as well as interference in the 2.4ghz band could be causing issues. Wifi really isn't a good measure to test gigabit because it won't max it out.
Are you running QoS? If so disable it. it really isn't needed if you have gigabit speeds.
EvinDtv
Aug 12, 2019Aspirant
Router Firmware Version V1.0.1.90
- plemansAug 12, 2019Guru - Experienced User
did you factory reset after updating firmware? Always make sure to update over a hardwired connection and to factory reset it afterwwards.
If you haven't, try this. I've found it helpful with the RAX line.
- EvinDtvAug 12, 2019Aspirant
Yes, after updating it I performed a factory reset. I also just tried again to turn off QoS and it limits both wifi bands to 54Mbps. I'm not sure what is wrong with this router but have seen many posts about similar issues and slow speeds. Is there any known firmware issues or a specific one I should try rather than the newest available?
the only other thing I'd try would be to downgrade the firmware to an earlier version to see if it is a bug.
If that doesn't work, I'd see about either going through support (free 90 days support) or doing an RMA for it.
