rcolon1989
Oct 30, 2025Follower
Slow upload speeds on router
Do you have a custom firmware for an RAXE300 SN:
I have the same issue as everyone here. Been thru multiple service appointments at $99 each. Multiple of the Verizon Fios 211 ONTs, but it work...
Oct 31, 2025Guru - Experienced User
So speeds were good at the previous home location with the RAXE router and this new location is not working? Seems like if the RAXE was working with prior location and not this new one, would be a ISP issue.
How are you speed testing? Wired PC or wireless devices?
Does ethernet connected PC with Ooklas installable speed test app show differences or same slow speeds?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Does ISP require any special WAN, PPPoE or VLAN configurations to make a external router work with there ONT?
