itzbigengland
May 19, 2020Follower
Slow WiFi Speeds - RAX 120 Router
Modem : Netgear CM1200 Modem Firmware : 1.02.02 Router : RAX 120 - Nighthawk AX12 Router Firmware : V1.0.1.122 ISP : Cox Communications (no issues reported in my area at time of trooubleshooting)...
lmanpunk
May 23, 2020Star
Same problem with the RAX200. I have tried many of the suggestions here but the problem comes back. Slow Wifi, Wifi Completely disappears. Looks like Netgear has serious issues with AX
- 19Andromeda86May 24, 2020AspirantIt would be great to have a link to previous firmware versions where the bug had not yet existed. Not sure which one that would be.
- michaelkenwardMay 25, 2020Guru - Experienced User
19Andromeda86 wrote:
It would be great to have a link to previous firmware versions where the bug had not yet existed.All previous firmware is available on the support pages for your device.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware for your device. Take your pick.
