itzbigengland
May 19, 2020Follower
Slow WiFi Speeds - RAX 120 Router
Modem : Netgear CM1200 Modem Firmware : 1.02.02 Router : RAX 120 - Nighthawk AX12 Router Firmware : V1.0.1.122 ISP : Cox Communications (no issues reported in my area at time of trooubleshooting)...
lmanpunk
May 23, 2020Star
Same problem with the RAX200. I have tried many of the suggestions here but the problem comes back. Slow Wifi, Wifi Completely disappears. Looks like Netgear has serious issues with AX
19Andromeda86
May 24, 2020Aspirant
It would be great to have a link to previous firmware versions where the bug had not yet existed. Not sure which one that would be.
- michaelkenwardMay 25, 2020Guru - Experienced User
19Andromeda86 wrote:
It would be great to have a link to previous firmware versions where the bug had not yet existed.All previous firmware is available on the support pages for your device.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware for your device. Take your pick.
