itzbigengland
May 19, 2020Follower
Slow WiFi Speeds - RAX 120 Router
Modem : Netgear CM1200 Modem Firmware : 1.02.02 Router : RAX 120 - Nighthawk AX12 Router Firmware : V1.0.1.122 ISP : Cox Communications (no issues reported in my area at time of trooubleshooting)...
19Andromeda86
May 24, 2020Aspirant
It would be great to have a link to previous firmware versions where the bug had not yet existed. Not sure which one that would be.
michaelkenward
May 25, 2020Guru - Experienced User
All previous firmware is available on the support pages for your device.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
It will also have any firmware for your device. Take your pick.
