itzbigengland
May 19, 2020Follower
Slow WiFi Speeds - RAX 120 Router
Modem : Netgear CM1200 Modem Firmware : 1.02.02 Router : RAX 120 - Nighthawk AX12 Router Firmware : V1.0.1.122 ISP : Cox Communications (no issues reported in my area at time of trooubleshooting)...
Joi007
May 25, 2020Tutor
Under wireless settings please uncheck "Enable 20/40 MHz Coexistence" and see if that corrects the problem.
- lmanpunkMay 25, 2020Star
I have already disabled that along with AX. Drops still occurs I also tried different channels for 5GHZ, I have went back to older firmware but that did not help. This is most likely my last Netgear. Support is not good. The community is better than support. RAX200 is not worth the cost.
