stepnup
Feb 25, 2023Guide
Slow Wired Speed to internet vs. Wireless Wireless better performance than wired?
Strangest behavior that is consistent and reproducible. Poor speed to internet via wired devices, great via wireless.
Raxe500 router with CM2000 modem. Subscription internet speed is 1.5Gb/40...
Feb 27, 2023Guru - Experienced User
Make sure you're not using any QoS, traffic monitoring, access controls, or parental controls on the RAXE. Also disable armor if you're using it.
What firmware is on the router?
(also, doubtful you're NAS is hitting 999mbps. While ethernet doesn't have as much overhead as wireless, it still has some and tends to max out around that 940-950mbps)
If you test speeds directly off the modem with your pc, what speeds do you get?
