rubenvazz101
Sep 23, 2020Follower
Slower ethernet speeds
So ive had my dlink router for about 3 years now and its served me well, never had any major issues. It handled my 500 mbps wifi speeds just fine. So now ive bought a netgear rax15 and although i did...
Christian_R
Sep 30, 2020NETGEAR Employee Retired
Hello rubenvazz101,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
