roninremy
Mar 22, 2022Guide
Smart Connect Specific 5ghz
I tried to look for this, but I can't find anything, and I am pretty sure I know the answer but need to confirm.
I want to lock my macbook/iphone to a specific 5ghz channel. Currently it only uses the upper 5ghz channels on the slower 2400(Canada we only have this option), where I want it to use the lower 5ghz channels on 4800 (I know it won't help speed that much but it does a bit, tested without smart connect)
The only thing I am aware of is going into terminal with the macbook and forcing it to a channel but I don't want to do that as I have no idea how to reverse that if I ever want to go back to normal.
Wanted to know if there is other way to forcing the macbook/iphone onto a specific 5ghz band? As I do not want to use the upper bands. Thanks
Disable SC and set the specific channel on the 5Ghz radio that you want your devices to use.
What Mac Book model do you have?
I know I can use this command
sudo /System/Library/PrivateFrameworks/Apple80211.framework/Resources/airport --channel=NUMBER
(where Number is channel) I was going to use this, but I don't know how to reset it if I want to see all bands again.
Macbook Air M1
It max Phy is 1200 and can only use 80
If it's only rated at 1200Mbps then either radio should work. You'll not get more out of this. My Mac Book Pro 2018 only does 1300Mpbs on AC.
Check with online support sites on how to use that command or ask Apple.
I know we were on the prior discussion so a couple things.
1. the only way to choose a band is to disable smart connect.
2. you don't need to disable it. even if the macbook connects to the 4800mbps band, like you said, it doesn't really help much.
And without knowing what actual macbook you have, its tough to know if it even supports 160hz wide channels. If it doesn't, it won't help at all.
