MSBOWL's avatar
MSBOWL
Follower
Jun 06, 2020
Smart connect with RAX75 router and AC2100 Genie as an AP
I'm new to the community and need some help. upgraded to Nighthawk AX8 enabled WIFI with smart connect & Beamforming enabled.    Poor coverage in lower part of the home. Configured Genie AC2100 as...
  • Christian_R's avatar
    Jun 10, 2020
    Hello MSBOWL,
    It is up to the device to connect to the network with the best signal. You may try naming the SSIDs different to see if there is any improvement.
    Christian
