Nucarojl
Sep 27, 2022Follower
Smart TV (Samsung) buffering problem
I've got a Nighthawk AX12 12-Stream AX6000 WiFi Router Model RAX120 Settings from my phone app when checking various devices tell me that the Smart TV is connected with the 5G speed. However,...
michaelkenward
Sep 27, 2022Guru - Experienced User
Which Smart TV? Most models that have cropped up here are limited to 2.4 GHz. That is fast enough for most uses and is often better than 5 GHz which has a shorter range.
One solution to smart devices is to use an Ethernet connection, most Samsung TVs have that feature. No need to run a cable. You can use Powerline Ethernet to turn your mains circuit onto an Ethernet link.
