scoobycarolannc
Jul 13, 2020Tutor
SmartConnect causing TV issues
I got my RAX120 about 3 weeks ago and it was very stable at first. Then I activated "Smart Connect". My house has 2 of the new AT&Ttv boxes (basically android TV streamers) and they were constantly...
Christian_R
Jul 16, 2020NETGEAR Employee Retired
Hi scoobycarolannc,
If you recently purchased the device, I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may start by registering your device using the link below.
https://www.netgear.com/support/default.aspx
Christian
