BarryD0706
May 22, 2025Aspirant
Some Android apps can't transfer data
I have a RAX120 WiFI-6 router, Ethernet-wired to a T-Mobile Home Internet modem. (I normally keep the WiFi radios in that modem off.) It's been working without problem for several years now. I re...
- May 22, 2025
The home modem probably has a built in router already. If so, This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATCouple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/kb/en-home-nighthawk-knowledge-sharing/procedure-to-configure-static-ip-address-for-ap-mode-for-netgear-orbi-or-nightha/2456243
May 22, 2025Guru - Experienced User
Couple of options,
- BarryD0706May 22, 2025Aspirant
Thank you very much for the quick response!
These T-Mobile modems have almost zero configuration capability. Even turning off the radios was a hack someone had discovered, and now that doesn't even work anymore. You are absolutely right that double-NAT is occurring (but it hasn't been a problem until now).
I will try your option-3, which will hopefully be OK since I'm not using Guest mode.
Appreciate the insights.
Thank you so much!
Changing the RAX120 to AP mode has solved the problem.
I'm still not understanding why double-NAT is bad (as long as the address ranges don't overlap), but I'll re-read the doc you pointed to. I guess these apps are passing back what it thinks its translated address is to some server, but that can't take into account the NAT done by the modem's router?
- FURRYe38May 23, 2025Guru - Experienced User
Its having two routers and two translations that cause problems when only one translation and one routing device is needed between the ISP services and connecting device. Have two in the mix can cause confusion in the apps and translation from one network to another. For some, a DMZ or IP Pass thru feature can help on the 1st router for a 2nd router downstream.
- BarryD0706May 23, 2025Aspirant
Thanks.
I've been working that way for over a year with no problems...and now with this setup (RAX120 in AP mode), certain websites aren't working. I can access many others, but often google.com, youtube.com take forever to load or give an error message that the network connection was lost. Don't see anything in the Netgear router logs. Appreciate your help.
