GKL_SC
Jun 18, 2024Aspirant
Some devices keep saying incorrect WIFI password when it is not incorrect
It doesn't happen on all my WIFI connected devices but several different types and brands of devices will keep saying the WIFI password is incorrect when it is correct. Is this a problem with the ...
- Jun 22, 2024SUCCESS! I found a solution that worked for me, hopefully this info might help others too.After researching even more online I found a suggestion to try creating a guest wifi network on your router.So I gave it a try and it WORKED to get my 3 Reolink Argus PT cameras connected to my new router.Now while I feel like it wasn't necessary in my case to give the guest wifi network a password without any special characters I did it anyhow and used just numbers and letters (the cameras had connected to my old router with a special character in that password)Another point to remember is I think you need to have your phone on the same network when adding the cameras.Just checked and it seems you need to make sure your phone is connected to the guest network when wanting to access the Reolink cameras you connected thru the guest network. (now I have other brand cameras that I connect to the main network that I can still access when on the guest network but an indoor Reolink camera I have E1 that I was able to connect to the main network I can't access thru the guest network like the other brands.Now I did try seeing if I could switch the cameras back to the main wifi but it didn't work and I have to remove and reinstall the camera I tried it on and add it again to the guest wifi network to access it again.Well, I guess having to switch networks when wanting to go from the outside Reolinks to the inside Reolink is better than buying a new router or new cameras and I am simply thankful I could get them to finally reconnect as I was beginning to think I'd have to replace them with other brands of cameras.
GKL_SC
Jun 19, 2024Aspirant
Thanks for your reply, and if I was connecting a new device for the first time and it didn't connect then I could understand maybe a password with special characters might be the problem, but the devices that won't reconnect are ones that I think the old password had a special character and had connected to the old router but I am not sure as I can't find what my old password was right now. I guess I could try changing my router password to not having any special characters but then I'd have a lot of devices to log in the wifi again 🙂
GKL_SC
Jun 20, 2024Aspirant
ADDED NOTE: I remembered what my old wifi password was on my previous router and it had the same exact special character included and my Reolink cameras originally connected back then, so that would seem to indicate that (at least in this instance) that using that special character in the new password with my new router should likely not be the cause of not being able to connect to my new router.
- KitsapJun 20, 2024Master
GKL_SC wrote:ADDED NOTE: I remembered what my old wifi password was on my previous router and it had the same exact special character included and my Reolink cameras originally connected back then, so that would seem to indicate that (at least in this instance) that using that special character in the new password with my new router should likely not be the cause of not being able to connect to my new router.
Old router and new router can handle password verification differently and there could have been a firmware update on your camera. Even if the routers are the same brand, the newer firmware can handle password requirements in a different manner.
