Retired_Member
Dec 01, 2019Some old devices cannot connect anymore to AX40 after firware update
Hi, at the begining, three months ago when I purchased the router, among all my devices, only a D-Link camera could not connect to wifi (can see the 2,4Ghz network but cannot connect - no solutio...
Retired_Member
Dec 02, 2019Router firmware is V1.0.3.64_1.0.1 so...the latest.
Already triued with Factory Reset and nothing happens, still not visible. I can understand that new firmware are released daily but functions should not be cutted off.
Dec 02, 2019Guru - Experienced User
A couple things you can try.
1. Disable DFS channels by going from 160hz down to 80 hz wide 5ghz channels. You'll set your speed from 2400mbps to 1200 mbps. this will force 80hz wide channels. Some devices can't use DFS channels and end up having issues.
2. Check your password. Some devices have issues with special characters. Something to try is to disable wifi security (temporarily) and see if the devices will connect.
3. Enable/disable beamforming. Usually doesn't fix the problem but its worth a shot.
4. Enable/disable airtime fairness.
- Retired_MemberDec 04, 2019
Many thanks for all tips.
I did the following:
- Enable implicit BEAMFORMING: tried on and off
- Enable AIRTIME FARINESS: tried on and off
- lowered down 2.4Ghz mode from "up to 300mbps" till "up to 54mbps"
- removed special carachters from wifi 2.4Ghz password
Problem persists.
- plemansDec 04, 2019Guru - Experienced User
The RAX devices are pretty new. Have you tried downgrading a firmware version, resetting, and seeing if it'll connect?
- Retired_MemberDec 08, 2019
Hi, I´m not just a big fan of downgrading, always wottied about lacks of features and stability.
