Gport16
Mar 22, 2024Aspirant
Some or might be all Wireless devices can't connect to WIFI if OFDMA andor MU-MIMO seperately are on
Noticed if running OFDMA and MU-MIMO is enabled (one at a time or both at same time) Some devices can't connect to WIFI. So yes, it's possible some older devices, still 5GHz don't support support MU...
- Mar 22, 2024
Actually looking at older post I did (I'm revisiting) they issue was
Beamforming - Already was enabled
Airtime Fariness- Just enabled and seems OK......
MU-MIMO - Currently disabled
AX Mode- I had this enabled but then could only use 1 oif the 5hz channels. The other one either couldn't be seen or couldn't connect with known good password. So I turned off and was fine after.
Gport16
