Gport16
Mar 22, 2024Aspirant
Some or might be all Wireless devices can't connect to WIFI if OFDMA andor MU-MIMO seperately are on
Noticed if running OFDMA and MU-MIMO is enabled (one at a time or both at same time) Some devices can't connect to WIFI. So yes, it's possible some older devices, still 5GHz don't support support MU...
- Mar 22, 2024
Actually looking at older post I did (I'm revisiting) they issue was
Beamforming - Already was enabled
Airtime Fariness- Just enabled and seems OK......
MU-MIMO - Currently disabled
AX Mode- I had this enabled but then could only use 1 oif the 5hz channels. The other one either couldn't be seen or couldn't connect with known good password. So I turned off and was fine after.
Mar 22, 2024Guru - Experienced User
What model router do you have? RAX200?
What FW is loaded on the router?
What older devices do you have?
Is Smart Connect disabled or enabled?
What is the security mode your using on the router? WPA2 or Mixed mode WPA2/WPA3? There are known issues with older devices not being able to connect if mixed mode is set with WPA3 in the mix. Something with these older devices can't connect, even though WPA2 is present. Would be a quick test to see if you disable wifi security with OFDMA and MIMO enabled at the same time, does any of the older devices connect at all? Re-enable WPA2 after checking this.
What channels are you using?
- Gport16Mar 25, 2024Aspirant
Yeah RAX 200
Firmware? Latest that was available via Netgear, but issue persistent between firmware's so ruled out, I suppose
Mainly couple older laptops 4-5yrs Newer ones too
iphone XR - Also had same issue, only 1 channel
No
Not mixed
2.4 and 2- - 5ghz
Thanks on "testing" possibilities
- FURRYe38Mar 25, 2024Guru - Experienced User
Try with SC enabled as well as a test.
