Gport16's avatar
Gport16
Some or might be all Wireless devices can't connect to WIFI if OFDMA andor MU-MIMO seperately are on
Noticed if running OFDMA and MU-MIMO is enabled (one at a time or both at same time) Some devices can't connect to WIFI.  So yes, it's possible some older devices, still 5GHz don't support support MU...
  • Gport16's avatar
    Mar 22, 2024
    Actually looking at older post I did (I'm revisiting) they issue was
    Beamforming - Already was enabled
    Airtime Fariness- Just enabled and seems OK......
    MU-MIMO - Currently disabled
    AX Mode- I had this enabled but then could only use 1 oif the 5hz channels.  The other one either couldn't be seen or couldn't connect with known good password.  So I turned off and was fine after.
