NERaptorRunner
Mar 24, 2020Star
Sony Bravia cannot connect to hidden networks on RAX200
Sony bravia xbr65x850d cannot connect to hidden network on RAX200. This was working on previous CISCO EA9500. Connects and works great if SSID broadcast is turned on. Only device left having issue...
Mar 24, 2020Guru - Experienced User
Have you tried disabling AX?
Maybe its an issue with AX and hidden SSID.
labatt
Mar 24, 2020Mentor
Why are you hidding your ssid? if you think it makes things secure you might want to read this article. Hidding ssid can also cause windows PC's to have connection issues.
- NERaptorRunnerMar 24, 2020Star
labatt wrote:Why are you hidding your ssid? if you think it makes things secure you might want to read this article. Hidding ssid can also cause windows PC's to have connection issues.
Thanks for interesting article. Good point.
