joy5toys
Jun 22, 2022Aspirant
Speed Test
Our community has gotten fiber service and got 1 Gbps service with our ISP. I'm using: NETGEAR Nighthawk AX8 WiFi 8-Stream AX5700 WiFi Router with latest firmware available. The conc...
Jun 22, 2022Guru - Experienced User
RAX###?
What are your wired speed results with a wired PC connected to the ISP modem? Same at the router?
Use Ooklas installable speed test app on the wired PC.
joy5toys
RAX75
Firmware: V1.0.6.138
ONT Manufacturer: Nokia
Model: unknown, S/N available externally
Factory reset has not been done. Kindly, provide resource for performing factory reset if recommended
As I have shared in my original post:
Wired PC to ONT connection speed test: > 900 Mbps download & > 500 Mbps upload
Router speed test: Download: around 550 Mbps & Upload: around 500 Mbps
- michaelkenwardJun 22, 2022Guru - Experienced User
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Always do this when you have changed your Internet service. You want it to forget any settings carries over from the old Internet service.
Also done wired?
- joy5toysJun 22, 2022Aspirant
Thank you very much for the link.
1- Wired: Router ---> ONT using Cat5 cable provided by ISP and running Netgear's own speed test available through the Netgear Nighthawk iOS APP: Download: around 550 Mbps & Upload: around 500 Mbps
2- Wired: PC ---> Netgear Nighthawk router running speed test in Chrome: Download - 655 Mbps & Upload - 440 Mbps
I will do the factory reset procedure and see if that improves things.
Thanks.
- michaelkenwardJun 23, 2022Guru - Experienced User
Not the most reliable speedtest. Try few others.
