H6G
Sep 14, 2019Aspirant
SQ. FT. Coverage....
I'm planning of buying the RAX200. ON the Amazone's product comparison chart, it states that RAX120 covers 3500 sq. ft., however, RAX200 can only cover 2500 sq. ft.? how can that be? is it a missprin...
- Sep 14, 2019CPU is slightly faster but not something that’s going to make a night and day difference, but I believe Qualcomm’s WiFi chipset is better and they usually implement ancillary features like MU-MIMO in a more functional manner.
avtella
Sep 14, 2019Prodigy
The RAX200 is just a RAX80 with an extra 5Ghz band. Having an extra 5Ghz band won’t boost coverage.
The RAX120 uses a better chipset made by Qualcomm and has 8 antennas for its single 5Ghz band vs 4 each for the two 5Ghz bands on the RAX200. Higher model number doesn’t mean better in every aspect. For the average home user even one with lots of clients I’d still probably not recommend a triband router from my own experience, Id say go for the RAX120 if deciding between the two.
Also be careful of just going off of the box estimates. Coverage also depends on home construction and obstacles and placement of a router. My home is mostly wood/drywall interior so I can get great coverage and speeds even in my basement with my router on the 2nd floor conversely a family friend with a house with more concrete interiors and granite flooring gets much lower speeds in their basement with the router just one floor above.
- H6GSep 14, 2019Aspirant
Thank you very much for clearing things up. So it appears that the processor in RAX120 is more powerful than in RAX200? I will definitely get RAX120.... instead of 200.
Also, do you know if I could connect (via WiFi) two RBS50 mesh units to RAX120, to increase coverage even further?
- avtellaSep 14, 2019ProdigyCPU is slightly faster but not something that’s going to make a night and day difference, but I believe Qualcomm’s WiFi chipset is better and they usually implement ancillary features like MU-MIMO in a more functional manner.
