TomServo
Jul 21, 2025Aspirant
ssid help
how do I add new ssid names to a rax36 router? I changed the nest of the guest ssid but I need 2 more names so I don't have to change several items that are locked into my old router names... đ
- Jul 23, 2025
The RAX series only supporting the main WLAN with Smart Connect enabled and one Guest Network SSID. You can disable Smart Connect on the main WLAN and have two separate SSIDs there. The Guest Network only allows for one SSID.
CrimpOn
Jul 22, 2025Guru - Experienced User
TomServo wrote:I had 4 different names on my old Netgear router
And that router was ???
