TomServo
Jul 21, 2025Aspirant
ssid help
how do I add new ssid names to a rax36 router? I changed the nest of the guest ssid but I need 2 more names so I don't have to change several items that are locked into my old router names... đ
- Jul 23, 2025
The RAX series only supporting the main WLAN with Smart Connect enabled and one Guest Network SSID. You can disable Smart Connect on the main WLAN and have two separate SSIDs there. The Guest Network only allows for one SSID.
CrimpOn
Jul 22, 2025Guru - Experienced User
That could be WMR1000v3 (version 3)... Except.... I find nothing in the User Manual about defining multiple WiFi SSIDs.
TomServo
Jul 23, 2025Aspirant
I did... I know very little about thus stuff.. I only upgraded because of just 10 to 15 in speed to 400.. old router was killing the speed...
