Carolynn
Jun 12, 2020Aspirant
Ssid not found on laptop
I'm having a problem where 2 work laptops can't find the ssid. Both our mobile phones can see the ssid and connect to it with no problems. I also haberdashery a dlink covr mesh network which bot...
schumaku
Jun 13, 2020Guru - Experienced User
Intel WiFi adapters? Update the drivers -> https://downloadcenter.intel.com/ Older drivers often don't reconn or connect WiFi 6 radios.
- CarolynnJun 13, 2020AspirantI'll check that, because the work laptop has so many restrictions I'll see if I can do it or get IT to do it remotely.
Not sure what chipset it has but will check
