lordtom
Jan 21, 2025Aspirant
SSL Nucleus and Netgear Routers
Hello all, So I have an old RA6700v3 router and just go Verizon FIOS. I ordered a new AX5400 router and could not get this thing to work on my MAC using the latest Sequior OS. When I plug in both ...
lordtom
Bad spelling, it should be Sequoia which is the latest Mac OS...
- plemansJan 21, 2025Guru - Experienced User
routers don't care what OS you're using.
If you were having an issues, I'm betting it was a settings issue.
In terms of your speeds changing, are you using smart connect? That combines the 2.4ghz and the 5ghz (not even sure if that router supports smart connect). 2.4ghz is a much slower network and sensitive to interference. 5ghz is significantly faster. Wired will be faster still. (doubt the R6700 would hit 800mbps over wireless).
- lordtomJan 21, 2025Aspirant
Not sure about smart connect, the 800 number is from the wired connection to my Mac Studio m2.
800 over wired connection sounds correct. for the R6700 2.4ghz might be 50-80mbps and 5ghz maybe 300-500mbps (under optimal conditions).
What actual issue were you having with the new router?
