MichelleMattie
Jul 06, 2022Guide
Starlink & AX1800 WiFi 6 Router
I cannot get my new AX1800 router to connect to the internet through Starlink. I have plugged and unplugged it all. Still no internet. Any suggestions before I return the router? Thanks for your help...
- Jul 06, 2022
Thanks for your help. I got it to work by bypassing the Starlink Router. LOL - this is not for the inexperienced and faint-hearted! 🙂
MichelleMattie
Jul 06, 2022Guide
The only one I think that they have (non-business).
Jul 06, 2022Guru - Experienced User
They've got more than 1.
Plus if you're cascading routers, you're in a double nat.
Try putting the netgear in access point mode and then connecting it to the starlink router.
- MichelleMattieJul 06, 2022Guide
I don't know how to put the netgear router in access point mode...and I can't get in the app - it's stuck on setup mode because of no internet connection.
- plemansJul 06, 2022Guru - Experienced User
Don't use the app. go through the browser setup method.
using the browser you can put it in access point mode
