MichelleMattie
Jul 06, 2022Guide
Starlink & AX1800 WiFi 6 Router
I cannot get my new AX1800 router to connect to the internet through Starlink. I have plugged and unplugged it all. Still no internet. Any suggestions before I return the router? Thanks for your help...
- Jul 06, 2022
Thanks for your help. I got it to work by bypassing the Starlink Router. LOL - this is not for the inexperienced and faint-hearted! 🙂
MichelleMattie
Jul 06, 2022Guide
Ericglanz
Jul 16, 2022Aspirant
How did you end up setting this up? I’m running into the same issue. I’ve set mine up so that the Gen 2 Starlink goes directly into the Ethernet port on the back of the main AX1800 router. When I’m testing speeds I’m only getting about 10mbps of download l, which what my prior speed was so I don’t think it’s working properly. Stand-alone the Starlink router was over 100+
- MichelleMattieJul 16, 2022Guide
I ended up returning it...nothing I tried would make it work.
I am now using a TP-Link router and it's working fine for what I needed.
